On Jul 3, 5:13 pm, Joerg <
[email protected]>
wrote:
[email protected] wrote:
On Jul 4, 3:03 am, Jim Thompson <To-Email-Use-The-Envelope-I...@My-Web-
Site.com> wrote:
http://analog-innovations.com/SED/EmitterCoupledOscillator.pdf
Not exactly a realistic circuit. Where is the OP going to get 500k
resistors? It isn't an E12 value, or even E24.
C'mon, that's just an entry from the sims. Use 470K, 499K, whatever.
And a 0,265V voltage swing isn't all that useful. The classic two-
transistor emitter-coupled multivibrator has a free collector output,
usually used to drive a third - complementary - transistor as a
saturating switch to provide a rail-to-rail output.
And why use the 2N3904? The BFR92 has much lower internal capacitance
(and a much higher bandwidth) and could probably run with less than a
microamp in either leg. The BFT92 could serve as the saturating
switch.
Well, then go all out and use a BFP620
0.22pF C-E. But be careful, that thing really rocks, ft is 65GHz.
The aren't much good at very low currents and there's only one in the
package. The UPA861TD looks better on these points.
