Hello Everyone
I am trouble shooting one of my PCB's that uses the microchip MIC4609 mosfet driver (I have attached the datasheet). I have it running the motor without any problems but everytime I enable the driver via the EN pin I get a massive current spike that can some times be up to 38A. The Spike only occurs when the enable is driver, if the enable stays on I can adjust the PWM duty 0-90% rapidly without it happening again. This even happens if I have the PWM at 0% and then enable the pin when there is no motor attached... (see trace below-Blue is PSU current and Red is Phase output - High side source)
I tend to think it must be the bootstrap caps, but they are only 0.1uF each, doees not make sense... Below is part of the schematic used (R38 is not fitted and R37 takes ISNS to GND as I had problems with noise in the early days).
Any Idea's?
Any Idea's?
