Arouse1973
Adam
Hey Chris
Had a go and got some good results. Changed my setup a bit. Wound 15 turns of 1mm wire around the resistor (0.33R) and a series connected 200nF. Connected 100nF across resistors and wound up frequency until the signal peaked across resistor. Peaked at 1.5Mhz, this works out to be 112nH. Did the same thing for a 470R but reduced the capacitance across the resistor to 470pF. Results again 22uH. I had the same thought as you last minute about removing the coupling issue.
@Steve .This has been fun, Thanks.
Cheers
Adam
Cheers
Adam
