Measuring SNR of telephone line
BobG
record a received tone of 1KHz. Analyze it. Anything that's not 1KHz is
distortion. Take the ratio of signal amplitude to noise amplitude.
Jack// ani
Few confusion....as usual
Why only 1Khz...not something else, like voice signal? How to seperate
voice signal and the noise signal?
BobG
You already know the phone line has a bandwidth of about 300-3K. If you
also know that the max signal is 0dbm or .775V coming in, just measure
the noise level of a quiet line. sn is 20log(noise/.775)
Don Bowey
What test equipment do you have to measure with? Once we know that we will
be able to help you.
Pooh Bear
Because accurate calibrated measurements are made with respect to a
'reference level'. It's simplest to provide that with a single tone. 1kHz
is also in the centre of the telephone frequency band, so a good choice.
Graham
Jack// ani
Nothing more than a DMM and PCScope!! How should I proceed next.....
Dr. Anton T. Squeegee
Pop over to greed-bay, and see if you can find an auction for the
appropriate test gear. If it's just a simple noise or line-quality
measurement you're looking for, you can probably get away with something
like a Wilcom T236 (analog meter) or T336 (digital meter) subscriber
test set.
If you're really serious about this, as in wanting to do detailed
readings of noise, phase jitter, and other in-depth variables, search
ebay for 'Hekimian' or 'HLI,' and you will likely find any number of
their high-end transmission test sets that, while old (they date back to
the mid-1980's), are reasonably cheap and will still do the job.
If Hekimian hardware doesn't tickle your fancy (and fair warning
-- Hekimian Labs has been out of business for years, so there's really
no manufacturer support for their stuff), you could try for something
like an HP 4935A or 3551A transmission test set.
Keep in mind that, no matter what kind of test gear you have or
get, you still need the originating central office to send out a 1kHz
test tone on the line in question. For that, you would need the
cooperation of your local phone company (good luck!) in the form of
telling you what the local test number is to get said tone sent back.
If what I've said above only increases your confusion, then you
need more education than I'm in a position to give regarding phone lines
and TIM (Transmission Impairment Measuring).
Happy hunting.
Dr. Anton T. Squeegee, Director, Dutch Surrealist Plumbing Institute.
(Known to some as Bruce Lane, ARS KC7GR,
kyrrin (a/t) bluefeathertech[d=o=t]calm -- www.bluefeathertech.com
"If Salvador Dali had owned a computer, would it have been equipped
with surreal ports?"
Jack// ani
I was wondering how to send 1Khz signal on my own line.......your post
left no more confusion now!!!
Thanks a lot
BobG
Use your computer as a signal generator. Have it put the tone in the
speakers. Put your cell phone in front of the computer speakers. Call
your home phone. Record the received waveform at the earpiece (gator
clips?). Analyze the recorded wave.
Ahhh... I beg to differ. That's going to introduce all kinds of
distortion that a reference test source, hardwired to the CO frame, will
not. The level will also be uncertain as blazes, whereas a reference
generator puts out a tightly-controlled 0dB.
Even if this idea works, the results will not be accurate. Better
just to hit up one of the local telco's field people for the test tone
number. That's how I used to do it.
Keep the peace(es).
Thanks a lot
You're welcome. To clarify further, the test tone is typically
produced by a device at the CO called a 'Test Line Responder.' It is
designed to, upon various commands (usually by TouchTone signaling),
produce test tones of varying frequency and intensity. It is usually set
for a 1kHz reference tone by default.
The most common one for your purposes would be 1kHz (1004Hz, to be
exact), injected at a level of 0dBm from the central office. This will
allow you to take very accurate readings (assuming the correct test
gear) of your line's loss and noise levels.
The best way I've found to obtain test numbers is to (politely!)
ask a telco field person. Technically, they're not supposed to give
those out, but I've run into many that do if they detect a kindred
techie-spirit in you.
Happy hunting.
Jasen Betts
You'll get distortion from the amplifier in the speakers piickig up signals
from the cell phone, distortion from the speakers, the microphone in the cell
phone, distortion from the encoding used to translate the audio into a
96kbps digital signal. distortion in the recording device (or if dirrectly
connected to the computer distortion from unbalabcing the phone line)
one rough and ready way to measure phone line distortion is to dial out to
an ISP using a 56k modem and see what connect rate you get.
using a terminal program it's possible to get information from the modem
about the line quality etc...
since the signals are digital from the CO to the ISP the only distortion is
on your local loop.
at&v1
TERMINATION REASON.......... LOCAL REQUEST
LAST TX rate................ 26400 BPS
HIGHEST TX rate............. 26400 BPS
LAST RX rate................ 49333 BPS
HIGHEST RX rate............. 49333 BPS
PROTOCOL.................... N/A
COMPRESSION................. N/A
Line QUALITY................ 025
Rx LEVEL.................... 016
Highest Rx State............ 67
Highest TX State............ 67
EQM Sum..................... 00A2
RBS Pattern................. 00
Rate Drop................... 00
Digital Loss................ 2000
Local Rtrn Count............ 00
Remote Rtrn Count........... 00
V90 9481834246E0
Don Bowey
Happy hunting.
Milliwatt test numbers are usually the office lowest nxx plus 1000. For
example your office may have 581, 582, 583, numbers; try 581-1000. If that
doesn't work try the rest.
Or........
Your telephone line attenuation is going to be in the range of about 2dB to
8.5 dB. You could ASSUME it's about 4dB and use that in your calculations
instead of measuring a test tone from the CO.
Don
