Doing some research to understand a bit more about a measurement I am
required to make, Group Delay. From internet reading, the definition
of group delay: - derivative of the change in phase over the change in
angular velocity. Tg = -d(theta)/d(omega)
It seems relevant to make as it will give some indication of the signal
distortion for a particular modulated signal. In my case OQPSK.
Now for praticality. Need a bit of help interpretting the results of
the measurement made using an HP8722D per the manual.
my case has a BW of 500MHz. The plot is a waveform with ripple over the
range. The spec I am comparing against has three components: Linear
(time/Bandwith), parablic (time/BandWidth^2), Ripple (time).
How do I get these results from a trace? The parabolic is the hardest
for me to conceptualize. Do I need to make some kind of interpolation?
Thanks.
Thanks.
