The noise has been very intermittent this morning. An average of 20 seconds on and 20 seconds off probably isn't too far from the truth.
Dorke: While the noise is gone, I get near identical voltages when comparing the A798s. When the noise is present, all four collector pins have about -36.5VDC. The voltage for the base pins do differ quite a bit from one transistor to the other, however. On the right one, I get 22mV, but the left transistor fluctuates in the -500mV range. Emitter pin on the right transistor is at 610mV, left one fluctuates in the 300mV range.
At this time, I can't get the noise to return, but I did include the pictures you requested just in case. I tried to get as little glare as possible, but this was very difficult since the bottom of the case is quite reflective. If it's not clear enough, I may have to try something else.
Edd: I happen to have a brand new Nichicon 47uF capacitor that I was able to connect between Yellow A and the ground next to it. At first, the noise vanished completely, but I wanted some confirmation so I played around with the knobs/switches. It eventually came back while I was messing with the Mono/Stereo knob. Then it vanished, and came back, etc..
Right now, even with the 47uF cap removed I can't get the noise to come back by messing with the knobs/switches. I don't know if it was the Mono/Stereo knob all along or just the vibration and luck.
When I first started diagnosing the noise problem, I sprayed all the knobs and switches with Deoxit hoping that was all it needed, but no amount of twisting, flipping, or bopping made any difference. If I "listen in" at the relay, for example, I can turn the Speaker knob from A to B to A+B to Off, and there is no change in the noise whatsoever. Same goes with Bass, Treble, Balance, Volume, Input, Tape Dubbing/Monitor, etc.. I tried them all with no variance in the noise at all.
There aren't any IC's anywhere in this amp. I checked the pink area specifically and found none on either top or bottom level.
I'll be testing this unit on and off all day to see if the noise returns.
