How many 150 watts mono solar panels are too many for a 12 volt 200 ah solar gel battery? Or will 4 number 150 watts solar panels be to much or many for the 200ah gel battery if I decide to put two each at front and back of my roof with a charge controller connected to each pair and merged together for the battery? I currently have two 150 watts attached and intending to add one or two more. I use 22′ tv and each time I need to charge my laptop, I usually put off other appliances because of the current being drawn. I am planning to get a small solar fridge hence the need for additional panel(s). I use the system mostly in daytime and for lights at night only. The system is also used mostly when it is in standby mode (hardly run it on circle mode) .I need your comprehensive advice and or comments.
Platforms
Content
