Platforms
Content
If the Ahr rating is 42, and you want to discharge it in 1/12 of an hour, what do you think the current would be?
Is this a question from a school assignment?
If not, then the answer in practical terms, is not so simple.
is mean that gives 42 Amper per hour--> in 5 minutes will give the 1/12 of 42..is that not right?
so..for only 30 mins will pass 84 amps?..?
i know that if i have 100ahr will pass 5 amps in 20 hours and 20 amps in 5 hours.. so in my case will pass 84 amps per 30 minutes..
The real answer is to check the datasheet for the battery you want to use.
However, if this is a theoretical question, you might like to use google to find out what current is required for car starter motors. You could also look at the "cranking current" that car batteries are rated for.
Ahr clearly allows you to determine how long a given load can run from the battery. (How long --- in theory -- would this 1200W motor run from your 42Ahr battery?)
There are other ratings which indicate the maximum current you can draw from the battery (without damaging it)
I have 1200 W power and 100 Amper
how can I choose a car battery? i have to find a car battery which have 100 amper?
A battery is not spec'd in Amperes (well, Cold Cranking Amperes maybe, but that's a different matter not to be considered here).
Being a school task, given that you have learnt about Ohms law and all that, what other (two) units can you calculate from those two units given?
Well, my guess is that the question is about the battery voltage needed to get 1200W at 100A.
