Sir Blackwellefty . . . . . .
and BOTH switch's being turned on.
THAT was being the bottleneck . . . . and now we're on a roll . . . . and you are doing GREAT!
You have to realize that at my end I am TOTALLY . . . blind, deaf and dumb . . . heavy on the dumb . . ., nor can I smell , feel, touch nor thoroughly physically examine a person's item.
Nor, do I know their technical acumen, expertise and prowess.
C70 97 volts.
C79. 78 volts
C71. 82 volts.
D64 77 volts
R83 79 volt
With those readings up above you are dealing with the bias supplies and all are telling me of a problem over in the tube circuitry, that we will have to correct in order get that area back to normal.
One error I do see, would be that if you had your black meter probe stabbed into ground those readings displayed are being NEGATIVE voltages.
Referring back to our post # 15 pictorial and schema snippet referencing
D65 across to the D67 77 volts
Now on the above reading we are being on a different level of power supply, which is supplying DC power for the filaments of the tubes.
With your referencing to the RED CIRCLE referenced cathode of the D65 diode, that also is the same connection as the cathode of the D66 diode to its right, that also is the same connection as the + terminal of the C73 electrolytic capacitor to the right.
We are interested in THAT capacitor.
Aditionally:
With your referencing to the BLACK CIRCLE referenced anode of the D67 diode, that also is the same connection as the anode of the D68 diode to its right, that also is the same connection as the - terminal of the C73 electrolytic capacitor to the right.
That C73 capacitor is rated as 25VDC maximum voltage and the filaments are expecting in the order of 12 VDC so we need to
re-check that voltage level again . . .with our fully expecting it to be down in the 14 possibly 14-16VDC range since it is now unloaded by any tubes presences..
The last voltage section info needed, was at the RED and BLACK dots associated with the D60-61 and D62-62 test points . . . . . . which I see no voltage info being given.
Finally . . .no worry . . . about the slight PCB discoloration, with time / heat from those resistors proximiy to the PC board.
73s de Edd
