Sir Blackwellefty . . . . . .
OK on the meter . . . it should absolutely more than is required to accomplish all of your needs.
I am expecting it to already be set up with its :
BLACK TEST LEAD in bottom center terminal.
RED TEST LEAD in right bottom terminal.
METER FUNCTION one click clockwise from left off position, up to its DC-Pulsating DC voltage function.
With the ONLY need for the Red lead ever being moved to the left bottom terminal, being for a series connected measurement of the 10 amps AC or DC function. (
Which we will not be doing.)
OPERATIONAL PLAN:
I have placed both photo information and additional schematic snippets of them just below on your initial info that I posted.
Do you have preference of mastering one over the other in the future or need I include both ?
The first readings now needed from the unit, is the
NEGATIVE voltage coming out of the tube bias power supply.
AC POWER now applied to the unit and being turned on.
You will notice that at the bottom there is the BLACK CIRCLE and off from it, I have given you 3 options of making your BLACK PROBES connection to . . . pick your easiest to find.
Then there will three readings taken from the RED PROBE to the marked in RED CIRCLE and its marked three offshoots from it.
Initially we need the voltage being metered at either the anode of diode D 64 OR the lead of R 83 that also connects there
OR even the lead of R 124 that
ALSO connects there.
All are being the same . . . .just use your easiest to find, and log down and pass that voltage being found.
Next voltage to find would be the voltage being on the
OTHER lead of R 83 and log it.
The last voltage would be the one at the
OTHER lead of R 124.
There is a high probability that all of these readings may be the same since we do
not have any tubes plugged in and presenting their loading, yet.
Now we move to the filament supply for the tubes of the unit.
It is a simple placing of the BLACK METER PROBE to any of the same component connections to a common ground
Which are being either two capacitors or the common anodes of D 67 or D 68.
The RED METER PROBE goes to either D 65 and D 66 diode cathodes or a shared 5 other resistors and capacitors that also connect there.
You log down that voltage to pass on.
Final voltage test for now will be the high voltage being used on the tubes, at this time we will only be needing the right RED highlighted voltage .
The BLACK METER PROBE goes to any of the BLACK DOT connected ground connections like D 62 or D 63 anodes connect to.
The RED METER PROBE goes to any of the RED DOT connected supply connections like D80 or D 61 cathode connections.
We need that voltage reading.
If you are squeamish on probing that voltage level , use my mentioned remoting of your test probe leads via the two clip tipped test leads referenced to.
That will be the worst that we will be encountering, and really, will probably be working on down in the 50 VDC range.
But we gots to knows what we gots !
Standing by for incoming readings or for assist if any procedural questions arise.
BOARD / SCHEMA REFERENCING:
73s de Edd
