N_Cook
In for a problem in heater wiring, corrected and working fine on the bench.
Reassemble in cab and no output now. I'm loathe to have to now take the main
board apart unnecessarily if I'm doing somrthing silly as there are a number
of awkward quirks about this model.
Feed signal in the "Return" and it outputs to the speaker. Normal signal to
the front input and output at "Send". There is 0R across all 4 un-inserted
"return" socket contacts as per schematic. ch select switches and status
LEDs work but pressing the muting switch does not mean the 3 LEDs come on
together now as a reminder indicator (this function not mentioned in the
user handbook). I've removed the digital board and nothing seems amiss with
that (secret lock within the XLR). Relay click at initialisation at power
up.
up.
