Sir Jonawald . . . . . .
Well at least we can see that part or all of this hand unit is supposed to be running on 5VDC, supplied by the 7805 regulator on the end.
And if you have popped transistors, I might suspicion them to be the larger Q407, Q403 and the hidden one under the hook up wire matrix is
probably also being the same type.
I can see that one IC is a 74LS32 which is a standard quad nor gate . . . .but its not looking good for the other IC, since its having 18 pins and that is
not going to be a conventional logic chip . . .HOPE . . .that it was not damaged.
Was this hand unit working in earlier times. ****?
What are the voltage specs on the two electroltytics on the board.***?
Am I correct that the blue wire is the one that brings the raw . . .supposed to be 24VDC . . . to the left terminal of the 7805 on the board.***?
I would just take an educated guess that when you were running the linear actuator as a load on that supply, it would be loading down to
about a 29 volt level, but as soon as it was stopped the supply voltage would shoot on up to approx 39 volts, with it not being loaded.
So you are saying that this new power supply is wired to this hand unit, but are other boards being tied into this power supply also? ( I HOPE not )
For 65 + years I have always had a Variac . . . .eventually accumulating 5 of them . . .and I would have had it supplying the primary of that transformer
and adjust it to set the power supplys DC outputted voltage at 24VDC and tested the actuator, to see how much its loading would then drop that voltage under load .
Then bring up the AC to get 24 again while running the actuator, and bring back down just before turning the actuator off.
This remote board might be working with two supply voltages, the 5VDC, from the 7805 which we can see present at the end of the board, and a lower
voltage or possibly the full 24V. (++ In your case) to some of the transistors.
Your minor, small sized TO-92 cased transistors are probably LED drivers being interfaced with that 18 pin mystery IC's outputs.
I couldn't make out any ID #'ing on it from your photo.
Your far right terminal of the Regulator is the 5VDC output, in a power down state, how about ohmmming between that pin and the pin 14 of the 74LS32 to detect a
short and thereby confirm that they are running that IC at 5VDC.
Then probe all of the pins of the 18 pin to see what might be shorted to the 5V regulator output for being its supply line, to confirm that it was also running at 5VDC.
The top spec for the 7805 is 35VDC input voltage I SURE hope that this unit was beefy enough, that it held up to a bit more than that max voltage input spec .
Waiting for feedback . . . . whenever you're being able.
73's de Edd
No graphics references were utilized in this post.
