Hello again
I want to make light device but a bit more complicated than the first one :
https://www.electronicspoint.com/threads/increasing-voltage-or-current.278975/
I decided to use a microcontroller so can play with different patterns of lights.
now I have some questions to ask if you do not mind:
First of all what kind of hardware do I need to start programming a microcontroller . like debugger or programmer etc..
Second what kind of microcontroller should I use AVR or PIC since I just started to use microcontrollers.
Third ,I have simulated ATMEGA 16 on Proteus and programmed it on Codevision before.but now I am making something on the electronics board not on the simulation software. so what kind of software I need ? I mean for designing the board , programming ,debugging (i prefer C language over assembly if its possible)
and last question what model of microcontroller should i use i want to play with 10 SMD's I need 10 output and some input for signals (if i am right?)
