Here is an easy problem for you guys (probably). You have probably answered questions like this before, so sorry for any repetition here.
I am trying to design a circuit whereby at a certain voltage a switch will operate allowing a linear actuator to extend.
My idea currently is that you have a circuit with a variable resistor allowing you to control the voltage on the circuit.
What I want to happen is for when the voltage reaches a certain point, the switch to close enabling the actuator to operate.
The thing is I just have one power source. So both the actuator and the switch would have to be on the same circuit. Also this would be a very low power circuit, so the actuator would need to operate at very low power. In fact an actuator might not even be the best solution.
Any advice or criticism is welcome.
EDIT: By the way if you instead wish to direct me towards some good reading material, that is also welcome.
