I'm trying to get around 4V for a project from a 5V input, but while following the designs in http://www.telit.com/fileadmin/user...ads/3G/Telit_UL865_Hardware_User_Guide_r7.pdf as well as http://cds.linear.com/docs/en/datasheet/1528fb.pdf and none of the resistor combinations or even strict adherence to the low ESR caps, and still when ever there is a load put on it, the voltage drops at least half a volt.
Without a load, I get from the linear site's resistor configuration, 3.95V. I put a 20Ω resistor on there which should be just under a fifth of an amp, but then the voltage measured across the resistor lowers considerably more than what the datasheet indicates it should, and the actual load I measure matches the new voltage divided by the resistance.
I checked the power supply, which is just an ATX attached to a breakout, and there are no anomalies there.
I've tried varying the capacitance on both input and output, but the behavior is the same either way.
I've also measured the input pin to make sure it's getting sufficient voltage, and the sense pin is 3.27V which is probably around where it needs to be.
I've also tried swapping out the regulator with another one, but that doesn't really help.
This is frustrating.
Please anyone tell me if there are some pit falls with this particular linear regulator, or can anyone suggest a better circuit, preferably one where the regulator comes in through hole rather than surface mount?
