Lt spice: Is there a Freq transfer function (table: frequency, transfer, phase)
Ronald Buining
I use Lt spice.
I want to design an inputfilter for a circuit of which I have:
- the transfer function (table: frequency, transfer, phase)
- the input impedance as function of frequency (table: frequency, transfer,
phase)
What function can I use in LtSpice to import these tables into the
simulation. I cannot find a function for it.
If it is not possible with LtSpice is there a alternative for LtSpice which
can do this. If needed I can spend up to a few hundred dollars.
I can understand that it is only possible to simulate ac transfer. That is
ok. I am interested mainly in simulating the ac transfer function of this
circuit including the inputfilter.
Thanks,
Ronald
H
Helmut Sennewald
Ronald Buining said:
I use Lt spice.
transfer, phase)
which can do this. If needed I can spend up to a few hundred dollars.
Thanks,
Ronald
Hello Ronald,
You can either use the classic E- and G-sources with Freq-tables
and PSPICE syntax or you an use the B-sources from LTspice.
Bv-source:
V=V(1,0) MAG FREQ=(1e6, 0.893, -26.7) (2e6, 0.705, -45.2) (5e6,
0.37, -68.3) (10e6, 0.195, -78.7)
Bi-source
I=V(1,0) MAG FREQ=(1e6, 0.893, -26.7) (2e6, 0.705, -45.2) (5e6,
If you send me your email address, I will send you an example with E and B
sources.
You can download this example also from the LTspice Yahoo group.
http://tech.groups.yahoo.com/group/LTspice/
Files > Tut > freq_table_E_B_1.asc
http://tech.groups.yahoo.com/group/LTspice/files/ Tut/
Best regards,
Helmut
