Low-voltage rail for transistor bases?
L
Lauri Alanko
Hello.
When power transistors are used as switches, the base current can be
significant, as the saturation beta may be as low as 10. On the other
hand, the base _voltage_ need only be at Vbe(sat), and any additional
voltage needs to be dropped by e.g. a resistor. Given the high
currents, this voltage drop may be a significant loss.
This suggests to me that ideally the base of a low-side NPN switch
would be powered by a low-voltage rail, only slightly higher than
Vbe(sat). This way the conduction loss would be minimized.
Has such a rail been used with bipolar switches? If not, what's wrong
with my thinking?
(Please don't tell me to use MOSFETs because they are better. I know
that already. I'm looking for understanding, not solutions.)
Lauri
Phil Allison
"Lauri Alanko" <
** No doubt - but it would still have been a 5 or 12 V rail.
But the DC voltage being switched might be several hundred.
.... Phil
W
whit3rd
hand, the base _voltage_ need only be at Vbe(sat)...
would be powered by a low-voltage rail...
with my thinking?
Yes, of course. Old NIM (nuclear instrumentation module) power for switching
transistors included +24, +12, +6, -12, -24V power supplies, and
it was common to make use of whatever was most convenient and
efficient from the plethora.
Vacuum tube radios typically had A battery for filaments (1 to 6 V), B battery for
tube bias (20 to 30V) and C battery for plate supplies (as high as you can get).
Sometimes, you see Vbb for base drive voltage supplies, Vcc for collector.
