Tim Shoppa
In the perfect world there would be a flash-based microcontroller,
serially programmable, that could run off a single cell (meaning 0.9V -
1.8V or so).
PIC16LF62x's go down to 2.0V (with some reasonable temperature limitations)
and are very hobbyist-accessible. (OK, there are some minor points
about verifying the flash at low voltage but those aren't biggies).
2.0V is OK for two-cell operation, but I want better.
The Fairchild ACE 1502 is good down to 1.8V, is serial EEPROM programmable,
etc. Not nearly so much stuff floating around the 'net about using them.
And they are still two-cell operation.
The Winbond W541L200 looks good down to 1.2V, which is good enough for
single-cell use (if still not ideal in terms of using the full discharge
curve). But it's mask-ROM programmable only and a complete non-starter
in terms of hobbyist tinkering.
Is there anything obvious that I've missed out on?
I may end up learning about single-cell-input voltage boosters instead of
searching for more low voltage microcontrollers. The TI TPS61001 series
looks good at a first glance, any alternatives?
Tim.
1.8V or so).
Tim.
