John Popelish a écrit :
Yes, thank you for reminding me the point of a negative resistance CT
burden. The lase application I saw was extending the low frequency roll
off of an ELF coil antenna.
Recently I had the opportunity of a design making use of this for a CT.
The first estimation was extending the LF cut off from a few Hz down to
under a 10th Hz.
One thing you have to take care of is that copper has a 0.4% tempco, and
a total negative resistance will obviously have a nasty behaviour so you
have to take margins so that the resistance stays positive at the lowest
temperature. If you want to get closer to perfect you might design in
the same tempco for the negative resistance part, but you still have to
ensure to stay positive.
To get anything like best performance from an opamp burden, the opamp
would probably have to be mounted directly on the coil. Coming up with
a core material with high permeability at 50 MHz would also help. Even
the winding form would matter. It might make a measurable difference if
the secondary came back around the core to the starting point, rather
than going all the way around the core, forming a turn that was not
coupled to the primary.
That sure would help.
I have no experience with CFB opamps, but am looking for circuits that
allow them to shine. Do you have any feel for how the optimum value of
the feedback resistor depends on the shunt to ground impedance at the
inverting input?
The inverting input impedance is essentially a 50/100R resistance (plus
bonding impedance) and what drives the output voltage is the input
current. All the interesting properties of CFB opamps come from this.
For example (for a given opamp):
- the loop gain almost depends on the FB resistor (that is without
extrem FB networks, ie while the lower FB network impedance is
sufficiently higher than the input impedance)
- one interesting consequence is that you can achieve much higher BW
with a neg input node parasitics capacitance than with VFB opamps.
- another interesting point is that the summing node impedance is upper
bounded by the neg input impedance.
Does that mean that the core window should be no larger than necessary
to contain the two windings?
Not necessarily (think of a bifilar wound toroid for ex.)
The basic rule, but that's so obvious that I don't dare mention this, is
to provide means of reducing unlinked flux paths.
