Low Cost PS for 12 Volts, 250ma for a small DC motor
F
Fred
Hi All,
I'm looking for a means to inexpensively implement subject PS from a
240/120 mains supply without using a switch. Yep, I know that a SMPS
would do the job but can the job be done at less cost?
What I've looked at so far:
1) Capacitive Transformer. It looks like it might work except that I end
up needing large 22uF high voltage caps on the front end which are
expensive. Needs a switch.
2) Zener supply. Way too much power dissipated in the resistors. Needs a
switch.
3) CT transformer. Looks good but needs a switch.
Any bright ideas or is SMPS the solution??
Regards,
Fred
Joerg
Hello Fred,
SMPS is usually the answer here. Unless you are facing a gazillion units
per year I would look for off-the-shelf wall wart type supplies or small
power bricks that are rated for wide input voltage (90V to 260V or so).
Regards, Joerg
F
Fred
Joerg said:
Hello Fred,
Regards, Joerg
Hi Joerg,
Thanks for the reply. There could well be a large quantity of these
supplies needed.
Regards,
Fred
Rich Grise
switch.
When you say, "without a switch", do you mean, without having to
manually switch a toggle switch or slide switch?
I knew a guy once who made 120/240 battery chargers, and he used
a 240V relay. At 120V line voltage, it didn't pull in, so the
primaries were in parallel. At 240, the relay pulled in, and put
the primaries in series. A relay _does_ do switching, but I've
never heard a relay called a "switch". :)
Other than that, probably an SMPS, sorry.
Good Luck!
Rich
martin griffith
Good Luck!
Rich
ISTR that the famous legal firm, Dolby Labs had a product that had a
suitably rated light bulb in series with the transformer primary for
just this function. It helps if you have a constant power requirement
martin
John Woodgate
Dolby Labs made a laboratory noise-weighting filter, with lower power
consumption certainly, that did 120/240 V by putting a filament lamp in
series with the primary of the mains transformer. The primary voltage
stayed at about 90 V irrespective of the input voltage.
martin griffith
Ah, The light bulb, probably the worlds' simplest XOR gate
martin
John Fields
Hi All,
switch.
Why can't you just use a wall-wart, and what's this "switch" you
keep referring to?
Joerg
Hello John,
keep referring to?
Guess he means the 120/240 selector. Anyway, wall wart or power brick is
the way to go. Much easier during the agency approval.
Regards, Joerg
Pooh Bear
keep referring to?
He wants a 'universal' PSU without the need to change voltage taps. See "
240/120 mains supply without using a switch ".
For all practical purposes therefore, an SMPS.
Graham
Pooh Bear
Fred said:
Hi All,
switch.
3 watts makes a simple switcher just about viable.
I googled "power adaptor china".
One interesting hit was this.
http://www.manufacturers.com.tw/electronics/Power-Adapters.html
There's *tons* of outfits making this stuff out there.
Graham
F
Fred
Graham
Hello Again,
Thanks to everyone that has contributed to this thread. I do appreciate
the input. To confirm a question back a post or two, yes, we are looking
for a PS that adapts to 120/240 mains input.
Regards,
Fred
