Winfield said:
Fred said:
Winfield a écrit:
John Larkin wrote:
Winfield Hill wrote:
Here's a nice example of a circuit that pulls itself up by its
bootstraps - a high-voltage opamp follower featuring
electrometer-style high input impedances.
My design is meant to replace expensive high-voltage opamps, like
the PA97 offered by Apex, with low-cost superior-performance
low-voltage opamps, like those offered by Analog Devices (Stephan
Goldstein should enjoy this one). My goal is for an amplifier with
an offset voltage under 65uV and less than 1pA input current, yet
operating over a 430-volt signal range.
+420
_|
IN ___| \___ OUT - within
<1pA |__/ 65uV of input
-15
[snip]
Well, whaddya think?
OK, what am I missing?
http://s2.supload.com/free/WinsHVamp.JPG/view/
My input current-limiting circuit, transient protection for the
MOSFETs, a small isolated capacitor to absorb fault charge, a
protected guard circuit, and series resistors to limit the fault
currents if a MOSFET fails.
You have an extra zener with cap, unless you want to add an active
PMOS pulldown circuit to increase negative slew-rate capability.
That's my next version and pushes the parts count up to 38.
Nothing to take care of stability issues?
I mean bootstrapping the supply rails from the output defeats the
opamp's compensation capacitor and will almost surely get you into
trouble if this is not taken care of.
Did you actually build this or is it just a back of the envelop idea?
Yes, like I said, it actually has 40 parts, including
active pulldown. Sorry for the over-simplification,
I hadn't wanted to make a big ASCII drawing, but with
these subsequent posts, some of the detail is coming
out bit-by-bit anyway. feel free to ask away.
Here's the opamp compensation part. As you can see
the opamp has its own local HF feedback control, but
at a slower rate it can do what it wants to control
the MOSFET, which in turn positions the stack.
+420
input | |--+ dn3145
protection _____|________|
\__ _|_ | |
IN --|__|---|+ \ | _|_,
| >--+ /_\ 5.1V
,--|-__/ _|_ | 100k load
| | --- +---- OUT ---/\/\--- gnd
1.5mA
sink
As before, there are missing parts, like the MOSFET
resistors and beads to suppress RF oscillation, etc.
Then there's the "output compensation", which provides
for rolling-off the huge effective gain of the output
MOSFET stage in a controlled way, with capacitor poles
and series-resistor zeros.
+420
input Rg |--+ dn3145
\__ _|_ | |
| | >--+ /_\ 5.1V
| ,--|-__/ _|_ | 110k load
Cc | '----| ----+--/\/\--+ <-- Xo
gnd --||-+-/\/\--+-------+------+
,--||-- GUARD ---/\/\---' 1.5mA
| cable cap, etc sink
gnd MOSFET
The small compensation capacitor, Cc, is also coupled to
the input protection circuit with two back-back diodes
(that normally have no voltage across them) to insure it
rapidly follows input transients, and thanks to the input
resistors, helps slow them down. Cc is a high-voltage
part.
Likewise, if the GUARD connection is used, its capacitance
also contributes to controlling the output gain, but with
a series resistor as a pole, said resistor limiting its
effect on the output and helping to limit any transient
voltages that might arise from faulty use of the GUARD.
Note the output node, Xo. When a huge external transient
imposed on the circuit makes it to that point, all the
fragile items, like the opamp, with its supplies and
protection diodes, simply follow the node. The MOSFETs
have zener diodes with their gate resistors, not shown, to
insure that their Coss + Crss charge can't cause trouble
if (when) this happens.
These little tidbits help push up the parts count.
