Steve Carroll
I would like to wind a transformer with one "closely-coupled" secondary and
one "loosely-coupled" secondary, for current-limiting. I understand that
increasing the air gap in the centre leg of an E-core will decrease the
coupling co-efficient, but how do I do it for only one winding? If I use an
E-core with a gap and wind two windings on top of each other on one side,
will they be more closely coupled than a winding on the opposite side of the
core and can I then vary the coupling of the secondary by varying the
air-gap, while maintaining closer coupling between the primary and the
feedback windings? (As you can tell, I'm a relative newbie to fluoro
inverter design, but I'm willing to learn.)
(I've posted a drawing on my website, (12.5K JPEG):-
http://www.dolevoiceaustralia.com.au/question.html )
This is for a complementary drive rapid-start fluoro inverter. I want a high
voltage, ~1kV, to get things started, then under load or reduced frequency
I want
the voltage to drop heaps to one or two hundred volts.
Any help would be appreciated.
.... Steve
I want
.... Steve
