Thanks Chris for detailed explanation and introduction to RF transmission line. Before talking to you, I even thought about using normal short circuit line to output that magnified signal. How innocent I am! I think I have a lot of homework to do.
But just for a benchmark try, I am not sure whether a very short RF coaxial cable would reduce effects from such as impendence mismatch or other kind of signal loss? For example, I read from a paper a 5m long RG8 cable has a typical time delay of 50ns. A spice simulation of such a cable has significant effect on output signal. But as long as time delay decreases to 5ns, that effect is negligible. Does this mean a RG8 cable of no longer than 0.5m has no significant effect on my output signal?
For the load of the circuit, the output is designed to be connected to a parallel planar stainless steel electrodes, or simply a capacitor of ~5pF. I guess this is not an ideal impedence for both the transmission line as well as the power supply. Maybe I can use some resistors to make a better balance. Am I on the right way?
Electronics, like most scientific fields of study, is made up of subsets, that in their own right can be viewed as their own field of study. RF Theory & Design is definitely a valid subset. Within the RF subset, Antenna / Transmission Line Theory & Design could and does fill textbooks. Fortunately, you can access all the information you can absorb by doing a Google search.
That said here are some transmission line tidbits:
(1) The reason 50Ω was chosen as the characteristic impedance of coax used in radio communications is because a quarter wave vertical ground plane antenna presents a natural 50Ω load impedance. It is also the simplest of all antennas and requires no matching networks at all.
(2) The term "Transmission Line Characteristic Impedance" is the most misunderstood and misapplied term in the electronics lexicon. I would venture a guess that only 1 out of every 100 people that think they understand it actually do! I've actually seen posts where the OP was trying to measure it with an Ohmmeter!
(3) I've forgotten more about transmission lines than I remember.
(4) Other than loss per foot; Transmission lines should play a transparent role but they can only do this when properly terminated at both ends. When it isn't it becomes something other than a transmission line. IE it's no longer transparent to the circuit driving it or the circuit it's piping to.
(5) Transmission lines are analogous to water pipes. Ideally we don't want them to leak at all. Except for resistive and dielectric loss (which we can't eliminate) we want all the RF fed into them to come out the other end. A mismatched load or source will cause the transmission to (radiate) leak. If the mismatch is severe enough it will resemble an antenna more than a transmission line.
(6) In a classroom environment there are few test setups that demonstrate the idiosyncrasies of transmission lines better than (TDR) Time Domain Reflectometry.
Linear Amplifier:
Yes, I understand that the author is using a linear as a driver but that circuit and the device it drives does not present a proper load for it. Since the ionizer does not appear to dissipate any real power it stands to reason that a real load won't be reflected back to the linear. Linear's or for that matter, any RF power amp does not like this and can destroy either. A linear with Fold-Back may protect it from destruction but would also prevent full power output. The only thing I see dissipating power is R1 @ <10W.
Hey, I'm not suggesting that his circuit doesn't work. I'm just concerned that there's no mention of the above.
Stress Analysis:
These are tests that manufacturers perform much like the auto industry does crash tests. All components have voltage, current, frequency, temperature and humidity maximums. Some may even have atmospheric pressure, vibration, shock impact maximums spec'd out. These are not tests that the home shop engineer gets involved in because it invariably results in the destruction of the (DUT) Device Under Test.
Chris
