Sorry, got confused to who I was answering.. first bit, to the poster I
answered, last bit, to the first poster. Also, meant three mercury tilt
switches (not vibration type).
Also, how much tilt do you want? if it's less than about 45° from
horizontal, and if you want proportional sensing not switching, then maybe
a tiny joystick, mounted upside down, with a small weight on the toggle?
You'll have to experiment with the mass, and the length of toggle
extension, but it's cheap, and might be accurate. You can use op-amp based
comparison to a preset voltage made equal by reading the current value at
will, copying it to a sample and hold (LF412's are good for all these
tasks), and if the thing is moved, the voltage change can be detected.
Adjust sensitivity by gain (in the sensor amp) and hysteresis (in the
comparator stage). You could do this for both axes but you might get good
results from summing them and watching the combined output if it's not
important exactly what degree of movement occured in which axis.
