Looking for some HP16510B programming info
ajcrm125
I'm looking to make an app that will convert HP16510B timing info into
a VCD (value change dump) format. I can get the data from the
HP16500A, but I need the 16510B programming manual to know what the
block data format is. Does anyone have one that can scan that secton
for me? Manuals are like $30+ on ebay and I can't justfy that for
this simple project.
Thanks,
-Adam
K
Keyser Soze
Thanks,
-Adam
The portable analyzer 1650B/1651B uses the same analyzer as the 16510B module for the 16500 mainframe.
The programmer guide is still available on the Agilent server at:
http://cp.literature.agilent.com/litweb/pdf/01650-90913.pdf
It may have what you need.
ajcrm125
Hmmmm I took a look at the data and the manual and it lines up until
just after the preamble and then it doesn't seem to make sense. I
have a file's worth of trace data and if I use this format described
in the 1650B/1651B manual it says none of my PODS are active. :-(
Guess I still need the 16510B prog manual if anyone has it.
