Looking for simple Triac circuit
ted weber
Looking for a master/slave triac circuit to control a couple hundred watts,
where the triac circuitry senses the master load (device turned on), and then
it boots up the slave outlets. I thought I saw a really simple circuit several
years ago but now all I can find on the net are rather complex circuits with
several transistors, diodes, etc.
Thanks,
Ted
martin griffith
On Sat, 22 Oct 2005 20:31:41 GMT, in sci.electronics.design
Thanks,
Ted
www.epanorama.net good starting point for loadsa stuff
martin
Phil Allison
"ted weber"
watts,
then
several
with
** Those "really simple" circuits usually had a serious flaw.
When low current loads were used as the master, the triac was not reliably
triggered in both polarities resulting in a DC component reaching the other
loads - then the smoke got out.
........... Phil
ted weber
This application is specific, so the load will always be a couple hundred
watts on the master and the other loads.
Any idea where that simple circuit may be found on the net?
Ted
Pooh Bear
You think that " several transistors, diodes, etc. " = complex ????
I suggest you re-think.
Esp for a master slave configuration.
Graham
Ross Herbert
Thanks,
Ted
Try http://www.discovercircuits.com/Andy/Autopowerswitch.pdf
John Larkin
Thanks,
Ted
Just a current transformer over one leg of the master power line,
feeding the gate of a triac, said triac switching the slave.
John
John
That's a good solution for resistive loads, but if the master is some
sort of partially inductive load with the current lagging the applied voltage,
then the slave may see a somewhat chopped version of the AC line voltage. At
least on the first half cycle. That may or may not be a problem.
The four-quadrant gate action may take care of keeping the triac turned
on for half-cycles after the first.
Jim
Spehro Pefhany
Jim
Maybe unlikely, depending on the nature of the loads, but I'd be a bit
worried about possible asymmetrical triggering, leading to DC in the
winding of a transformer or motor which might be in the switched load,
and thus copious amounts of smoke pouring out and that sort of
embarassing outcome.
Best regards,
Spehro Pefhany
John Larkin
Jim
There are always unstated details, it seems.
Well then, you could rectify and filter the gate drive, or have the ct
drive a small rectifier/filter into a power ssr.
John
DaveM
watts,
then
several
with
Thanks,
Ted
You might be thinking of a circuit like the one at
http://ourworld.compuserve.com/homepages/Bill_Bowden/page8.htm#aclatch.gif
It's not very complicated, as power control circuits go.
If you absolutely want a triac to control the slave loads, just replace the
relay with am optoisolator and triac combination. You can also replace the
homemade current sensor with a real current transformer that will be more
predictable.
Dave M
MasonDG44 at comcast dot net (Just substitute the appropriate characters in
the address)
Never take a laxative and a sleeping pill at the same time!!
E
ehsjr
Thanks,
Ted
Look for "Jim Thompson Inspired Switch" in the abse newsgroup.
I'll be posting it today.
Ed
F
Fred Bloggs
ted said:
Thanks very much. Where is abse?
Ted
I posted this a while back, put a MOV across the L and N where they
enter your little *plastic* box containing the parts. It uses the Radio
Shack 10A relay (1200VA load). If your master load causes triggering
problems then you may have add a line rated 0.1U capacitor between its
switched line and neutral.
View in a fixed-width font such as Courier.
.. RS relay 275-217
.. .-------------------o----v
.. | o-------+-----.
.. | 1A ------ | |
.. | 400V .-|\ \ \ |-. | |
.. | TRIAC | ------ | | |
.. | | 22 | | |
.. | 1/4W | | | -|-- N
.. | | | | | - | E
.. | | | | | o| O
.. | 4x 1N4001 | | | |--- | N
.. ___ +---|>|--|>|------+ | | |
.. L ---| |--+---|<|--|<|------+ | | |
.. N ---| |--+-----------------|----------|---|-----'
.. GND---. | -------- | | | --------
.. | | | __ | | | | | __ |
.. | | | ____ | | | ____ |
.. '---------------O-------------------------------O |
.. | MASTER | SLAVE
Rich, Under the Affluence
It's the newsgroup, .
You need a real news server at your ISP (or I guess there are
news servers for hire out there these days). I notice you're
not a google poster, so you probably have it unless your
local sysop is censoring you. ;-)
Good Luck!
Rich
