Jamie
As it said.
We need to replace some analog PID boards due to supply and
side effects the existing ones have.
The PID code that comes in digital drives and process controllers
are pretty much what we're looking for how ever, we only need just
a design that allows a input ref, reference feed back and a output
to drive what ever device.
This device should have it's own mini LCD interface to set the
values or at least a computer hook up to do so.
It should have the standard Proportional Gain, Integral and
derivative components to set the values.
Also, having an option to select unipolar and bipolar output
is a plus!..
I know there are various analog boards out there already that
do this how ever, We have found that they seem to exhibit side
effects and cause self oscillation under some conditions.
In the digital varieties, I have found this not to be a problem
because it's being done via software and thus these effects are not visible.
I have already made a few using a AVR/ATMega that employ the ADC
inputs and we simply buffer the output into a PWM filter and op-amp.
These units are programmed via a serial connection for the params.
How ever, my employer wants to buy units that are ready made so that
replacements can be had with out depending on in-house designs.
I have looked and I can't find a unit that has a build on LCD display
with a simple interface to do this..
We do have a SSD out board key pad unit that does do this function for
us along with some other little nifty things how ever, it appears that
this unit is no longer available.
Any idea's?
is a plus!..
Any idea's?
