Mark Becker
Hello - (hope this is the right place .. pardon the cross-post)...
I was recently asked to come up with a circuit for rapidly turning off a
modest magnetic field (about 100 gauss) in a microsecond or less. Did a
little math, some thinking, and came up with a Helmholtz coil pair that
seems to do the right thing. Approximate inductance of the coil pair is
8 uH.
Turning the field off in under a microsecond was the difficult part..
but a hint in a reference suggested placing a zener across the
inductors. This was tried with a much lower current (and a much lower
field) and indications are that this will work. However...
Generating a 100 gauss field requires about 15 amperes. Turning off
that field by circulating the current through a zener means the zener
must (a) handle a pulse of 15 amps and (b) dissipate nearly 1 mJ in less
than a microsecond. The repetition rate is once every 5 seconds, maybe
a little faster if the research turns the frequency up.
I have found only one maker of pulse-rated zener diodes.. and while I
was able to get a few as samples, now a small quantity is needed (<100)
and these things are only sold in bulk. I don't need 12,000 or 25,000
diodes, not for a research effort.
Questions:
1. Anyone know a house selling small quantities of BZW03D100 diodes?
2. Anyone know a maker of suitable zeners?
3. Do I really need a high-power zener for this?
Your time is appreciated.
Mark
P.S. Postings to the newsgroup preferred.. however, if you e-mail a
response to this note, the e-mailer at stowetel will challenge. Please
ack the challenge.. it slows down the spammers. Thanks.
8 uH.
Questions:
Mark
