Ok, here's my project.
I work at a manure hauling company. We drive semis from the farm full of brown gold to the field. When we get to the field, we park on the side of the road and dump our contents into a roadside dumpster.
If we do this on a county road, seeing we block a lane of traffic, regulations dictate we must have "flaggers" (stop/slow sign operators). Only problem is finding labor willing to stand out in the elements.
I dug around, and according to the FHWSA, we can use AFADs (Automatic Flagger Assistance Device). More simply put, a trailer that sets where the Flagger would normally be. It must have certain operations (I'll describe in a second), and it may be remote controlled.
So here's my plan. I am currently building (2) AFAD trailers. At the rear most part of the trailer, there will be (2) 12" LED lights (red / yellow - picture a portable stop and go light, minus the green light). Immediately in front of the stop/slow light post, there will be a gate that drops down when the red stop light is activated. When the yellow light is illuminated, the gate will raise vertical, at the same time it will raise a shorter "slow" sign that will display.
On stop signal, the red light must flash for 5 seconds, then remain on steady. On slow signal, the yellow light must remain on steady.
On stop signal, an arm must be lowered (similar to a railroad crossing gate). The gate must have 3 lights along the gate arm. The furthest must remain on, the remaining 2 must flash alternating. (These 2 alternating flashing lights will also be wired to the tail lights, those will alternate flashing as well). The gate arm will be operated by a DC motor (think power window motor out of a car).
The AFAD will be powered by (3) 12v deep cycle batteries. They will be recharged via a small engine connected to an alternator.
The AFADs will be remote controlled, not automated (I will start another post on that issue)
I have drawn up a diagram that I believe will work. I'm looking for input on my diagram. Maybe someone can see a fault I made, or a better way to do something.
I appreciate the concern if anyone is wondering, but this plan / the AFADs are DOT/FHTSA approved.
Thanks in advance!
Thanks in advance!
