Looking for engineer to build a couple of small projects
RobC
Have 2 immediate needs: a device to measure maximum burst speed for
revolving arm and display on LED. Another device to measure maximum
burst pressure.
Stanislaw Flatto
burst pressure.
Just a small querry:
d<angle>/dt ?
dP/dt ?
What LED ?
Precision ?
When do you want it and where ?
Stanislaw
Slack user from Ulladulla.
RobC
d<angle>/dt ?
dP/dt ?
What LED ?
Precision ?
Stanislaw
I am located in Santa Barbara Ca, A couple months.
RobC
d<angle>/dt ?
dP/dt ?
What LED ?
Precision ?
Stanislaw
Not sure what
d<angle>/dt
dP/dt ?
What works right now conceptually for the device is a magnetic sensor
utilizing the teeth of a gear. Thus getting multiple readings within
90 to 180 degree.
What LED ?
any read out display with 1/2 inch tall numbers.
Precision ?
+ /- 1 to 2 %
Michael Black
burst pressure.
Engineers design, others do the building.
You need to define which it is you need.
And this isn't a newsgroup for offering jobs.
Michael
Jim Thompson
Michael
Sure it is... there are actually a few designers lurking here... in
spite of the dominance by hackers ;-)
...Jim Thompson
Jim Thompson
I was located in Santa Barbara for about 20 years.
Luhan
And then you moved to Arizona?? If I was wealthy I'd absolutely love
Santa Barbara.
...Jim Thompson
Tim Wescott
Michael
I see no problem with the guy offering jobs -- assuming, of course, that
monitoring this group implies that you can _do_ the job!
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
Posting from Google? See http://cfaj.freeshell.org/google/
"Applied Control Theory for Embedded Systems" came out in April.
See details at http://www.wescottdesign.com/actfes/actfes.html
L
Luhan
Santa Barbara.
...Jim Thompson
I prefer the weather in Arizona. You can have several hot and humid
months in SB late in the year, and the humidity is higher all year
round. Besides that, no matter how much you make, you get a house 4
times larger here, and a yard ten times as big.
Luhan
L
LRCR
burst pressure.
I am a circuit designer in NY. Can you tell me what time frame are you
looking to complete these projects and is there cost target for each
Project?
Stanislaw Flatto
RobC said:
Not sure what
d<angle>/dt ?# angular velocity, change of angle in unit of time
dP/dt ? # change of presure in unit of time
Both needed to determine the speed of response of the measuring
cirquitry, affected by required precision.
Precision ?
+ /- 1 to 2 %
Exactly what I said above, the circuitry should be at least 5 to 10
times more accurate to ensure what is diplayed.
Good luck and no thanks, am now in freezing "penal colony" so no
changing for the "other colony".
Stanislaw
Michael A. Terrell
Don't be ridiculous! A yard is 36 inches anywhere you go.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Michael A. Terrell
Not to mention a few whackers?
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
petrus bitbyter
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Nah, ours are longer. Only call them meter.
petrus bitbyter
Spehro Pefhany
petrus bitbyter
Must have answered one of those spams "add THREE INCHES to your
yard"..
Best regards,
Spehro Pefhany
F
Fred Bloggs
...Jim Thompson
Maybe- people tend to call themselves all kinds of things. The OP
specifies "a couple of small projects," is totally mystified by the most
elementary queries regarding specification in terms of differential
notation, knows nothing about tolerance, uses non-standard terminology
such as "burst speed" and "burst pressure" with absolutely no idea of
their definition, has no idea of the time frames, is totally oblivious
to environmental and safety/regulatory constraints, has no money most
likely, and in all probability has no clue whatsoever of what he really
needs, wants , or will be satisfied with. Sounds to me like a total
waste of time and a futile exercise in dealing with a nitwit.
