Looking For Data On Dreefs Rocker Switch, Looking for data sheet
I am looking for a technical datasheet on a Dreefs rocker switch.
I took some pictures of it ... and put them here:
http://www.8051bits.com/dreef-switch.jpg (might be bigger then one below)
It has all sorts of numbers on it, inlcuding
2215/1
2Wi11
WZ9
T100
T125
KZ18
I contacted the company that now owns Dreefs several weeks ago, and a few times since, and they have not answered.
Any help would be appreciated !
Hi dxpwny. Standard rocker switch, poles may vary, but most common is DPDT double pole double throw, both poles are make or break, iluminated by an internal lamp, some low voltage some mains neons, plus any series resistor, some are built in, some need an external resistor in series with the switches lamp. easiest way is use a continuity tester on a multi meter, this will give the contact arrangement.
