Hi. I'm trying to fix an old stereo amplifier (see also https://www.electronicspoint.com/forums/threads/fixing-a-stereo-amplifier.294254/), and I have desoldered the capacitors. That was a bit more difficult than I had expected, but (I think) they all came off without any damage to the PCB.
I had already tried to look up their replacements, but wasn't sure of one pair of capacitors, and now that I've got them off, I still don't know where to get two of the 4700uF/40V capacitors that can be seen in the image. The diameter is 40mm, it has three pins (positive, negative and dummy) and the distance between the pins is 25mm. I can't find any further information on them. I've searched mouser, digikey, alliedelec, future electronics, jameco and a few local stores, but none of them seem to have a single three pin electrolytic capacitor of that size.
Does anyone know if there is a replacement for them? If not, should I simply get a smaller 4700uF/40V capacitor with wire leads? If so, is there any need to secure them to the print board (because I think that's what the third pin is for)?
And about the other capacitors: there's a lot of choice for all of them, but with different ripple current (?) and ESR specifications. Is one choice better than another for audio applications?
Thanks in advance!
Thanks in advance!
