(snip)
???? a 3000VA inverter is going to want 250A @12V input, assuming 100%
efficiency. There IS a reason why higher input voltages are used as the output
rating climbs. Even my 1000VA unit runs a 60V string of 5*12V.
I absolutely agree.
However, since the originator of this thread wanted something that was
easier to "fail-proof" I thought that less cells might be better (even
if larger amperage capacity).
My 350 watt UPS has a single 12v/6ah battery - which I guess means
that at full power it might draw 30 amps (not for long!). So maybe I
should have said about 50 ah for 3kw if scaled correctly.
But you are correct about input power. I suppose that most UPS's have
the "inverter" part running in sync with the grid power all the time,
and the battery only gets called on when the grid fails.
Perhaps a standard 48v inverter would be better, but then there is the
problem of "all those cells".
I guess in the end, as others have said, the best system is a regular
maintenance schedule of replacing batteries at a set time period.
If the regular batteries in the UPS were re-sited OUTSIDE the box, it
might be possible to a) prevent the heat from one battery affecting
the adjacent ones and b) monitor the individual battery voltages more
easily.
Thanks for your comments budgie.
Eric Sears.
