Looking for a TIP145 equivalent
Dave
I'm looking for a replacement for a PNP Darlington Transisitor TIP145. I
can't find one around Brisbane (so it seems) and am wondering what people
would suggest as a replacement.
I'm a mug at electronics and of course my need is immediate otherwise I
could get one from Futurlec. DSE online appear to have them but who knows
how long I'd have to wait now the face is gone.
Out of interest, this component from the circuit board buried in a load of
foam in an old Repco 12V fuel pump. They cost about $140 these days!
The pump ceased to work suddenly but mechanically it is fine and the coil(s)
seem fine. I decided it was simple to replace all components once I opened
and cleaned it up. I am a bit puzzled how the thing works at all. It has
five resistors and three diodes plus the transistor and the two coils around
the iron slug that does the pumping.
Thanks folks,
Dave
Phil Allison
"Dave"
** I do not believe that DSE have ever sold that device.
But Farnell do:
http://au.farnell.com/multicomp/tip145/darlington-transistor-to-247/dp/9294562
Lotsa luck - pal.
..... Phil
atec 7 7
Thanks folks,
Dave
You could just go find a replacement pump at the progress road pick a
part at wacol for $10.00
news.uq.edu.au
Thanks Phil.
I'd never used Farnell. The mail wait could be a killer.
Next reply MIGHT be worth a shot.
Thanks again.
Dave
news.uq.edu.au
Thanks,
Wasn't aware of them but might just try that approach!
Dave
Phil Allison
"news.uq.edu.au"
Thanks Phil.
** Farnell do not use mail.
You would get nest day courier delivery in Brisbane.
..... Phil
Phil Allison
"glenbadd"
TIP147 is commonly available
** Huh ?
Not from DS, Jaycar or Altronics stores as the OP requires.
DS on-line have no stock.
So it is back to Farnell, RS and WES for one off quantities.
..... Phil
atec 7 7
Phil said:
"news.uq.edu.au"
..... Phil
nest day ?
is like your falatio philthy ?
Dave
Well,
I called the wreckers and they said yes, $21 and there were plenty of cars
with them. Called a second yard and yes, they had plenty at $20. So I took
half the day and went tehre. Spent a long tome looking and could not find
ONE - at either yard! Naturally aspirated vehicles are not THAT common and
I found none that had an electric pump. A Subaru Leone MIGHT have had! A
wasted afternoon!
Ooops . . sorry this is supposed to be electronics!
Dave
Dennis
Dave said:
Well,
took half the day and went tehre. Spent a long tome looking and could not
find ONE - at either yard! Naturally aspirated vehicles are not THAT
common and I found none that had an electric pump. A Subaru Leone MIGHT
have had! A wasted afternoon!
Dave
Try a 4WD wreckers, there may be some fitted to transfer fuel from reserve
tanks etc.
terryc
Is this a largish 3 pin square body with metal tab, or the domed thing
with flange?
Dave
coil(s)
around
Thanks folks,
Dave
The Go Company at West End have them listed in their catalogue for
$3.10ea:
http://www.gocompany.com.au/go1-10-11-12-13-14-15.pdf
Might be worth giving them a call to check if they have stock.
Andy
Thanks Andy,
I might do that when I have the new pump installed. . I still intend to
rebuild the old one. I won't let that sort of thing beat me.
Dave
