I have inherited a beautiful Loewe Xelos TV (Chassis Q2500), which I have been using with a digital TV Set Top Box since the demise of analog TV. However, it recently failed, and I am, for technical interest, trying to repair it.
The failure was in the main switch-mode power supply. The control chip and MOSFET switching transistor blew - bits of plastic case missing in both cases. I replaced these two components and the resistors connecting them - controller output to MOSFET gate. (There are two in parallel. Both had gone very high in resistance). All other components in the switch-mode circuit seemed to be OK. With the base board disconnected from all else, the switch-mode power supply then worked fine. The transformer produced the required secondary AC voltages.
Looking good. The re-assembled set however, misbehaves on startup. The standby power indicator (red LED) shows when mains power is applied. An 'On' command from the remote results in the following display sequence:-
Green LED (main power indicator) On
5 seconds
Red LED (standby power indicator) Off
2 seconds
Green LED Off and red LED On.
Nothing appears on the screen, but speakers provide the usual 'click' as the sound circuit becomes active.
A similar sequence results if the 'On' command is delivered by pressing the power button on the set in after mains power is applied.
I am wondering if there is a history of this type of failure that might indicate the likely problem, or if anyone has some thoughts on what to suspect.
(I have decades of experience in electronics, from valves -YES!- to microprocessors. This is my first look at a Loewe product however.)
5 seconds
2 seconds
