Moi
It's used in a load panel sticker that says something like "do not put more
than 150 amps on one stab".
What's a "stab"?
What's a "stab"?
Moi said:It's used in a load panel sticker that says something like "do not put
more
What's a "stab"?
Martin Riddle said:The individual 'slot'.
The fork finger that grabs the bus bare..Moi said:It's used in a load panel sticker that says something like "do not put more
What's a "stab"?
Is it one slot, or a pair of slots sharing the metal tab?
Its a BUS BAR or a BUSS BAR, dumbass.
OHHHHH< I forgot 1 "S"Michael said:Its a BUS BAR or a BUSS BAR, dumbass.
krw said:Yes.
Please don't let "Michael A. Terrell" see that.krw said:The correct spelling is "bus". "Buss" is a proper noun and "buss" is
wrong unless you're in love.
...and if it doesn't grab the bus bare it won't work. ;-)
For any one that really wants to know.. Don't take it from me.PeterD said:Well it could be a bare assed bus bar...
Please look there..DJ said:I should know better than to be vague.
Is it the space one circuit breaker takes up?
Is it the metal tab that two adjacent (end-to-end, not side-to-side)
breakers share?
Is it the space that those two breakers take up?
Jamie said:
DJ Delorie said:Is it one slot, or a pair of slots sharing the metal tab?
Ok, that's clear. The metal tab is the stab, it connects to two
breakers.
Yet there are ads on Google for 'Buss Bar' suppliers.
Come on. You know it needs a coat of No-Ox.
breakers.
krw said:Of course it depends on where you are, but two adjacent breakers are
usually on opposite sides of the line so the answer is the same either
way.
Aren't most new breaker boxes?
I've had to replace several with both
aluminum bus bars, netral and ground bars after one or more failed. The
new breakers i see have a contact lube in them.
Yes, exactly.DJ said:Ok, that's clear. The metal tab is the stab, it connects to two
breakers.
