Hello,
I have made a board based on an atmega328P, that reads a wav file from the SD card, and then plays it trough an LM4871 amplifier.
I followed the instructions on the datasheet for the LM4871, but I had no sound into the speaker.
It would produce a pop when I was changing the shutdown pin from LOW to HIGH and from HIGH to LOW, or more popping when I touched the pins with my hands, but that was all. Everything else is working fine, because I connected an piezo speaker directly to the output of the Atmega328P (aka the input of the amplifier) and I could hear the song playing.
NOW, after I fiddled a bit with it, I`ve connected together, by mistake, the Shutdown pin and the Bypass pin of the LM4871, and I started to hear sound coming out of the speaker. At this point I could hear "EUREKA" in my mind ).
Few days after this I`ve noticed that the amplifier was not shuting down anymore and it is getting hot,when I connect a speaker to it (also there is no input, the output pin on the 328P is set to LOW)
I`ve never made a schematic for my project. I only made the PCB design, so I had to make one now to show it to you, and for simplicity, in this schematic I used a Attiny85, instead off the 328P.
CAN SOMEONE PLEASE, PLEASE HELP ME WITH THIS?
What is the problem??
