Joerg
JosephKK said:BTW it makes it easier for others to follow and contribute ideas if youHenrik said:Dear Joerg,
Thank you very much for your replies. I will with a 50mR or so Rsense
tomorrow, Also I will try to get the scales and such nice info into the
shots.
write below the quoted text.
Stack a few of those for the test. 1uF may be a tad too small for a 1AAlso I will try exchanging the sepic capacitor to a large 1uF ceramic
capacitor that I have in stock.
switcher (tho it'll work). Nowadays you can get pretty good 10uF or at
least 4.7uF caps but even there you may have to parallel in order to
ease and share the current load. They have become quite cheap.
With switchers it is really important to carefully study the datasheets
of even the most mundane parts. We take those caps for granted in bypass
situations but here they'll have to slosh around a lot of energy. I
leaned that the hard way. Everything was fine for an hour or so. Then a
very loud bang, pieces flying around, and what was left from the
ceramic material of a capacitor had turned into green bubbly glass.
Quite pretty actually but it could have been a bad situation if I hadn't
worn eye protection glasses. Best to wear those when you work on
switchers and similar gear that can go "exotherm".
Since you are in Denmark this would be the perfect time for an ice-coldThank you so very much for your help. I will sleep much better now that I
see a possible solution to my problems ;-)
shotglass of Aquavit. Good stuff
Mmmm. Aquavit. Once in a while i get some Aalborg Jubilamus variety
aperitif, sugary but very tasty.
Aquavit isn't sweet. But it has to be served ice cold and ideally the
glassed should be chilled to where ice crystals form when you take them
out. Just make sure you don't have to drive anymore that day.
