LM334 based tempreature gain circuit
james
Thanks for the schematic for a circuit to do the job, certainly a lot
simplier than the multiple opamp and thermistor version.
I have decided to base the circuit on this design, but I have a couple of
queries.
The schematic specifies LM334 as the temp sensor, however upon looking at
the datasheet these sensors only have a operating range of 0deg to +70deg c.
The
required circuit operated beyond these ranges!
Does the LM334 not require an adjustment input, the sensor is a three wire
unit - or is two wire input ok?
Regards
