John Popelish
Mike said:Ok. To review.
The goal here is to use a current source. Initially the thought was to
use the LM334 as a current source to drive each string of LED's. Then the
idea became a mirrored Current source. But the LM334 current limits put
it outside the realm of driving LED's that need 20mA to reach their
brightness.
A constant current source is prefered due to the variations that can occur
within the automobile charging system, and the delicate nature of LED's
Information from CFoley1064 and Robert Monsen has been very helpful. So
now it's time to look at the preliminary design and look for issues.
Below is diagram using a LM317 voltage regulator in combination with a
resistor to ensure a fixed current source regardless of changes in
automobile voltage output.
Here are the planned devices to use:
12 Volts (as high as 14 v is possible, as low as 11)
1-EA LM317 (http://www.national.com/pf/LM/LM317.html)
1-EA 62ohm Resistor .1 watt 1% tolerance
6-EA 2N2905A PNP Transistors (Has Vceo of 60)
20-EA RL5-R3545 Super-Red LED Foward Voltage of
2.2 typical, 2.6 max (http://www.superbrightleds.com/leds/r2_specs.htm)
When wired as shown below, the goal is to achieve a current level of 20mA
across all of the LED's in a fairly even manner to achieve near equal
brightness across all of them. The theory being that changing the
resistor value can impact the amount of current flowing as it will impact
the setpoint of the voltage regulator.
Questions:
1) Are the devices listed above appropriate for the goals?
2) What is a good source for the above components. (LED's I know where to
go)
3) Any other comments or changes to the circut below recommended?
VCC +12
+-----+ V V V V V
| ____ | | | | |
| | | V V V V V
+--|LM317---+ - \\ - \\ - \\ - \\ -\\
|____| | | | | | |
| .-. V V V V V
| '-' V V V V V
GND -12
created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
I would eliminate the LM317 and add a resistor to each current source
emitter to make them track each other much better. I would set the
base voltage to one of them to force about .6 volts across its emitter
resistor.
Something like:
VCC +12
| | | 33 | | 33 | |33 | | 33 | |33
| V V V V V
| V V V V V
.-. V V V V V
| |1k | | | | |
'-' V V V V V
GND -12
No need for as spiffy a transistor as the 2N905A. I would probably go
with 2N3905. They have a plastic case that is much cheaper and they
are common as dirt. Even Radio Shack should have them. 2N4403 is
beefier but that is not much of a factor with 20 ma of collector
current.
