The 595 can only sink or source a maximum of 35mA per pin or a total
of 70 mA through Vcc or GND, so if you have 8 LEDs being driven per
package, that means the current through them should be limited to 8.75
mA each.
In one of your posts you mentioned an LED current of 8mA, so I guess
you figured that out already.
For 70 LEDs, that would be a total of 613 mA from the supply, and with
2V across each of the LEDs, the series resistors would be about 343
ohms each.
360 ohms is a standard value and would allow 8.3mA through the LEDs,
with a total drain on the 5V supply of 581mA.
In order to keep from having to split the supply, someone mentioned
using an oscillator driving a half-bridge totem pole at a rate high
enough to prevent flicker as your display changed.
Something like this:
Version 4
SHEET 1 1596 748
WIRE -128 -816 -256 -816
WIRE 160 -816 -128 -816
WIRE 464 -816 160 -816
WIRE 752 -816 464 -816
WIRE 880 -816 752 -816
WIRE 752 -784 752 -816
WIRE 880 -688 880 -816
WIRE 624 -672 560 -672
WIRE 736 -672 688 -672
WIRE 752 -672 752 -720
WIRE 752 -672 736 -672
WIRE 832 -672 752 -672
WIRE 1120 -576 1072 -576
WIRE 1216 -576 1184 -576
WIRE 1312 -576 1280 -576
WIRE 1424 -576 1376 -576
WIRE 560 -560 560 -672
WIRE 608 -560 560 -560
WIRE 736 -560 736 -672
WIRE 736 -560 688 -560
WIRE -128 -528 -128 -816
WIRE 160 -480 160 -816
WIRE 208 -480 160 -480
WIRE 528 -480 432 -480
WIRE 880 -464 880 -592
WIRE 912 -464 880 -464
WIRE 1072 -464 1072 -576
WIRE 1072 -464 992 -464
WIRE 208 -416 32 -416
WIRE 496 -416 432 -416
WIRE 560 -368 560 -560
WIRE 608 -368 560 -368
WIRE 736 -368 688 -368
WIRE -128 -352 -128 -448
WIRE 32 -352 32 -416
WIRE 32 -352 -128 -352
WIRE 64 -352 32 -352
WIRE 160 -352 128 -352
WIRE 208 -352 160 -352
WIRE 560 -352 560 -368
WIRE 560 -352 432 -352
WIRE 1072 -352 1072 -464
WIRE 1120 -352 1072 -352
WIRE 1216 -352 1184 -352
WIRE 1312 -352 1280 -352
WIRE 1424 -352 1424 -576
WIRE 1424 -352 1376 -352
WIRE -128 -320 -128 -352
WIRE 880 -320 880 -464
WIRE 464 -288 464 -816
WIRE 464 -288 432 -288
WIRE 560 -240 560 -352
WIRE 624 -240 560 -240
WIRE 736 -240 736 -368
WIRE 736 -240 688 -240
WIRE 752 -240 736 -240
WIRE 832 -240 752 -240
WIRE 1424 -224 1424 -352
WIRE -256 -208 -256 -816
WIRE -128 -208 -128 -240
WIRE 64 -208 -128 -208
WIRE 160 -208 160 -352
WIRE 160 -208 128 -208
WIRE 160 -192 160 -208
WIRE 496 -192 496 -416
WIRE 496 -192 160 -192
WIRE 752 -192 752 -240
WIRE 160 -176 160 -192
WIRE -256 -96 -256 -128
WIRE 160 -96 160 -112
WIRE 160 -96 -256 -96
WIRE 528 -96 528 -480
WIRE 528 -96 160 -96
WIRE 752 -96 752 -128
WIRE 752 -96 528 -96
WIRE 880 -96 880 -224
WIRE 880 -96 752 -96
WIRE 1424 -96 1424 -144
WIRE 1424 -96 880 -96
WIRE -256 -32 -256 -96
FLAG -256 -32 0
SYMBOL Misc\\NE555 320 -384 M0
SYMATTR InstName U2
SYMBOL cap 176 -176 M0
WINDOW 0 -33 32 Left 2
WINDOW 3 -39 58 Left 2
SYMATTR InstName C2
SYMATTR Value 1µ
SYMBOL diode 64 -336 R270
WINDOW 0 32 32 VTop 2
WINDOW 3 0 32 VBottom 2
SYMATTR InstName D3
SYMATTR Value 1N4148
SYMBOL diode 128 -224 R90
WINDOW 0 0 32 VBottom 2
WINDOW 3 32 32 VTop 2
SYMATTR InstName D4
SYMBOL res -112 -544 M0
SYMATTR InstName R8
SYMATTR Value 4.7K
SYMBOL nmos 832 -320 R0
SYMATTR InstName M2
SYMATTR Value FDS6930A
SYMBOL voltage -256 -224 R0
WINDOW 123 0 0 Left 2
WINDOW 39 0 0 Left 2
SYMATTR InstName V1
SYMATTR Value 5
SYMBOL res -112 -336 M0
SYMATTR InstName R1
SYMATTR Value 4.7K
SYMBOL pmos 832 -592 M180
SYMATTR InstName M1
SYMATTR Value FDS6685
SYMBOL voltage 1424 -240 R0
WINDOW 3 24 96 Invisible 2
SYMATTR Value PULSE(0 5 0 1u 1u 100ms 200ms)
SYMATTR InstName V2
SYMBOL res 1008 -480 R90
WINDOW 0 0 56 VBottom 2
WINDOW 3 32 56 VTop 2
SYMATTR InstName R2
SYMATTR Value 180
SYMBOL diode 688 -256 R90
SYMATTR InstName D5
SYMBOL res 704 -384 R90
SYMATTR InstName R5
SYMATTR Value 10k
SYMBOL cap 736 -192 R0
SYMATTR InstName C1
SYMATTR Value 100n
SYMBOL diode 624 -656 R270
SYMATTR InstName D7
SYMBOL res 704 -576 R90
SYMATTR InstName R6
SYMATTR Value 10k
SYMBOL cap 736 -784 R0
SYMATTR InstName C3
SYMATTR Value 100n
SYMBOL diode 1120 -560 R270
SYMATTR InstName D1
SYMBOL diode 1216 -560 R270
SYMATTR InstName D2
SYMBOL diode 1312 -560 R270
SYMATTR InstName D6
SYMBOL diode 1184 -368 R90
SYMATTR InstName D8
SYMBOL diode 1280 -368 R90
SYMATTR InstName D9
SYMBOL diode 1376 -368 R90
SYMATTR InstName D10
TEXT -32 -56 Right 2 !.tran .5 startup uic
TEXT 440 -496 Left 2 ;1
TEXT 440 -432 Left 2 ;2
TEXT 440 -368 Left 2 ;3
TEXT 440 -312 Left 2 ;4
TEXT 184 -304 Left 2 ;5
TEXT 184 -368 Left 2 ;6
TEXT 184 -432 Left 2 ;7
TEXT 184 -496 Left 2 ;8
Notice that since the duty cycle is 50%, the currents are allowed to
be twice normal, with 16mA peak available into the LEDs for the same
brightness as 8mA, CW.
A few more components and the brightness of the red and green could be
equalized, if that's important.
BTW, what LEDs are you using/do you have a link to their data sheets?
