Tom Biasi said:
I didn't catch the original post but I thought that this may be a good time
to mention that lightning rods are/were not designed for direct hits. The
purpose is to keep the accumulated charge below a safe level.
Not true.
Even some reference books claim the above. They've fallen for
a type of physics myth; a "science urban legend."
Yes, in 1790 they assumed that a little bitty lightning rod could
discharge a miles-wide thunderstorm across the miles of space above
the rod. The experts reasoned that, after all, a needle could
discharge the main terminal of an electrostatic generator even
if the needle was many inches away. Researchers later figured out
how silly this was.
Check out Dr. Martin Uman's book "LIGHTNING" for some ACCURATE
lightning-rod discussion. (It's probably unwise to listen to
any of the emotional and dishonest "belief systems" espoused in
this thread, including my own! Go see what lightning physicists
actually say. Experiments and mathematical reasoning will win
over politics and "beliefs.")
Still reading?
Well then it's your own fault.
Why can't a lightning rod discharge the storm? The scale is wrong.
While a needle can discharge an electrostatic generator via ion-leakage
across a large gap, a lightning rod is not like a needle. A lightning
rod is tiny: like one fiber in a piece of felt if we obey the scaling.
If one fiber is slightly taller than the others, well, the high voltage
electrode doesn't care. If you erect a lightning rod, the storm
won't even notice.
Also, the scale is wrong for "charged wind" to transport any charge
upwards. If you hold a needle near a high voltage terminal, the
needle "emits" charged wind which travels at many cm per second,
and there is a significant electric current in the air; on the order
of microamps or tens of microamps. This easily shorts out an
electrostatic generator.
But if we scale things up and use a lightning rod and thunderstorm,
the "charged wind" coming from the tip of the rod STILL TRAVELS AT
CM/SEC SPEEDS AND THE CURRENT IS STILL MICROAMPS. To have a significant
effect on the charged storm cloud, this velocity would have to scale up
too. The lightning rod would have to "emit" an electric wind that
traveled at tens or hundreds of KM per hour, and the electric current
would have to be thousands of times higher than 10uA.
Note that the above is one of several "lightning rod controversies."
Emotions run high in such controversies, so you cannot trust what
either side tells you. You can't even trust many reference books!
