I'm looking to add this 88 LB (40kg) Magnet Electromagnet Solenoid to hold together this gate for a bike project. When magnetized, the electromagnet will hold the steel plate on the gate and when de-energized the gate will drop flat onto the ground.
I'm looking for a circuit diagram to wire this. Aside from a 12VDC battery source, a switch and the electromagnet, what else would I need? I'm guessing a relay, cap and diode maybe? Someone who I met once and had built one of these circuits gave me a 16VDC 33000uF cap to use, but I just want to verify this. Any help preferable with a circuit schematic will be appreciated. Also if you can provide the specs of the parts needed to make sure I buy the correct parts.
Thanks!
Thanks!
