KrisBlueNZ it's all about technique and practice, there is not magic solution that will make it easy... The chipquick stuff works but it's not needed and costly for what it does, it's best to simply practice and get perfection... Also the chipquick stuff is lead based, fine for the US and those countries ignoring ROHS but not so good for those cracking down... You also don't have to spend the premium on the chipquick 'solder' it's just a low melt alloy every company has their own name for this alloy, some examples are 'Alloy 136' 'Indalloy 136' 'Low 136 alloy' 'Cerrolow 136' 'Lens Alloy 136' 'Bolton 136' and so on.... You can purchase a chunk of this and use slice off shavings with a knife to reflow... I have several pounds of it as I use it to make temporary custom jigs for my milling machine and sorts, you can double boil it like chocolate on a hotplate or stove and literally cast it in a cardboard mold, if you want a custom fit to a funny profile you an simply wrap the original part in plastic wrap and pour directly over it
Fun stuff to play with if you mind it's toxicity...
As KJ6EAD stated you use a higher heat for less time, but with the higher heat you have to adamantly remember to use less time or you are back to lifting pads... It's like riding a bike, hard at first but once you figure it out painless...
