I'm developing an electronic device in order to collect and store a
wide range of sensory (imagery, sound) data of an outdoor environment
This device will be installed in a remote area, high on a building (no
power lines) so it has to be self sufficient in energy supply. Because
of this remoteness, self maintenance and the not always so electronic
friendly conditions outside (rain, snow, heath of sunlight etc.) I see
it as a sort of ground based 'satellite' and as far as I can
see/feel (Hey... I'm a total novice) it also has to be constructed
similar to a satellite.
Everyday, for only a short period of time (a few seconds) it starts up
to collect the sensory the readings, which, to my latest estimates,
will take no more than 5 watts of power.
I'm not a professional engineer (but I'll get some help from a few) so
excuse me if I say things that are a little awkward or not that bright.
To provide the device with sufficient and long term energy, I'm
thinking to use about a square meter of a high efficiency solar cells.
My goal is to collect and store the data and keep the device running
over a long as possible amount of time, counting in years. What can be
said about a maximum life span?
Is the power source the main limiting factor just for example like the
30 year old space based satellite as Voyager and Pioneer which run on
radioactive decay reactors but if the electronics/transmitters will not
break down, will function and transmit data till the 2030's!
(http://en.wikipedia.org/wiki/Voyager_2)
Or are there other life span limiting issues like decay of materials
(for now I'll use a welded a Zinc casket filled with Argon (prevents
oxidation inside)).
A lot of weather conditions affect the efficiency of solar cells.
seasons, temperature, angle of sunlight etc.
http://www.solarelectricpower.org/index.php?page=basics&subpage=pv&display=qa).
But I've read, at the same website I believe, that the life span and
power generating properties are between 35-45 years!(?)
Besides of solar cells are there any other durable long life energy
sources which can be used?
Thank you for your attention and every comment is appreciated!
Regards,
Marcel
oxidation inside)).
Regards,
Marcel
