hi everyone, new here!
I have some very expensive wireless gaming headphones (my daughters) which do not charge up after 1.5 years (extensive) use. I suspected the battery was dead so ordered a replacement, but after soldering it in I’ve discovered it’s probably a problem with the charging circuit? The battery had some charge from new, and using the usb charging cable activated the ‘charging’ led indicator, however after charging for 5 hours the battery has died. Topping up the battery directly from a PP3 I again tried charging with the cable cable without success. A multimeter showed battery voltage steadily decreasing while it was ‘charging’.
So my question: can I take the regulating circuit board from a cheap power bank and wire this to the battery instead? I’m aware these batteries can explode if overcharged, that usb supplies 5.0 volts and the battery requires no more than 4.2 volts. Many thanks
