Hi All, Hope you all are well?
So a friend of mine asked if i could have a look at his hifi.
Its powering on but the sound is very soft even at full volume.
So at first i suspected a blown amplifier IC but upon further testing its the amplifiers power supply thats at fault.
Its supposed to give out 35v but theres nothing.
I stripped it and found and traced the 35v line to the transformer( it uses a smps for the whole system)
The secondary side has no output but the primary side has around 45v AC.
Then after further probing and checking voltages , i probed a zener diode on the primary side while negative of the multimeter was connected to earth and the thing starting working again, but gave out about 20v on the secondary but the amp is working.
if the unit is switched off, even in sleep mode then after about 3 or 4 minutes and switched on again then theres no output on the secondary unless i just probe it with the meter then it works for as long as the unit is on.
Any ideas where to start looking? im new to smps supplies, checked the caps, none leaking and they are samxon caps(good quality?)
any help would be appreciated.
Attached is the circuit diagram of the SMPS (i have the workshop service manual but its over 10MB)
