Roland Paterson-Jones
I posed this question some time back
http://groups.google.com/groups?hl=...5&[email protected]#link1
However, I have finally taken the trouble to work the numbers myself for
Nichia model NSPL510S, which is nominally rated at 2500 mcd (typical) and
2*phi-half of 50 degrees.
The conservative calculation (see below) gives 85 lumens/watt, which
surprised me hugely. Typical incandescent is apparently 17 lumens/W by
comparison, and CFL's apparently about 4 times that, i.e. about 70 lumens/W.
Can someone please check my logic and workings.
Data is from http://www.nichia.co.jp/specification/led_lamp/NSPL510S.pdf.
You will need to register to download the file, but it is free.
I used the directivity graph to plot the minimum (relative) intensity
according to half-angle for various discreet angles
(5,10,15,20,25,30,40,45,60,75). I ignored angles beyond 75 degrees, since
the intensity dropped below 2%.
Then, I used the formula, 2*PI()*(1-COS(PHI/180*PI())) in Excel to calculate
the steradians within a beam of half-angle PHI. Note that 'PHI/180*PI()'
simply converts from degrees to radians.
The steradians covered by each band (e.g. between 5 and 10 degrees) is then
simply the difference between the 5 and 10 degree total steradians.
Then I used the formula lumens = candelas * steradians to calculate the
total lumens output in each band. This is a conservative figure, since I use
the minimum intensity for each band.
Then the total lumens output of the LED is the sum of the lumens over all
bands. Here are the precise workings in CSV (comma-separated) - import it
into your favourite spreadsheet for a better view:
,Model,NSPL510S,1/2-Angle,Intensity,,Steradians,diff,Lumens,(cum)
,2phi(1/2),50,5,95%,,0.02,0.02,0.20,0.20
,Luminosity (mcd),2500,10,95%,,0.10,0.07,0.61,0.82
,Current (mA),20,15,98%,,0.21,0.12,1.05,1.86
,Voltage (V),3.6,20,80%,,0.38,0.16,1.19,3.05
,,,25,50%,,0.59,0.21,0.94,3.99
,Power (W),0.072,30,25%,,0.84,0.25,0.57,4.56
,,,40,10%,,1.47,0.63,0.57,5.13
,Lumens/W,85.22159065,45,8%,,1.84,0.37,0.27,5.39
,,,60,4%,,3.14,1.30,0.47,5.86
,,,75,2%,,4.66,1.52,0.27,6.14
,,,,,,,Total,6.14,
Note the total lumens is 6.14, and for a typical power rating of (20mA *
3.6V = ) 0.072W, this represents a little over 85 lumens/W.
The last column is the cumulative lumens output from the centre of the beam
out. Note that a little less than 2/3 of the light is generated within
phi-half (3.99 lumens in 25 degrees).
Comments?
Roland
Roland and Lisa Paterson-Jones
Forest Lodge, Stirrup Lane, Hout Bay
http://www.rolandpj.com/forest-lodge
mobile: +27 72 386 8045
e-mail: [email protected]
,,,,,,,Total,6.14,
Comments?
Roland
