Hi. I’m having trouble setting up a solenoid water valve controlled by an Arduino. I am following the guide here
https://www.bc-robotics.com/tutorials/controlling-a-solenoid-valve-with-arduino/
Except I am using a 12V solenoid with a power pack to power the solenoid instead of the Arduino itself, and I got the code from another site, which uses a web interface on the Arduino to control it.
It worked perfectly on the bench, but would not work once connected to the water. I even disassembled it and could not get it to work on the bench any more.
I have tested the power pack connected straight to the solenoid, this works.
I have replaced the transistor twice and tested the resistor with a multimeter.
I have probed for voltage when I press “on” and the Arduino does output 3.3V.
Should I be able to test for continuity to check the transistors? I'm thinking I received bad transistors.
Thanks,
Thanks,
