Hi guys,
I have a problem with a circuit i am modifying... Its a circuit from radioshack's electronics lab booklets. It uses the 4049 IC and the 4066 IC. It has adjustable speed using a pot., I didn't want that so I put in a 4.7k resistor to get the flash speed I wanted. It operates off of 6 volts and runs two leds alternating just fine. But I need it to run on 9 volts and run 4 panels of 18 5mm leds. All of it should be on a 9 volt battery for bicycle lighting or maybe two 9 volts. I put this circuit on a perfboard but it does not work correctly. It flashes out of sync and much faster. It also stores power in the ground terminals on the labs breadboard now when I tried to re do it on the breadboard to see whats wrong with the actual board on the perfboard. All wiring is checked countless times. Ohh and pin 9 of the 4049 is what is holding power to the ground.
Pictures are attached along with a schematic.
